Posté le: Dim Mai 10, 2020 18:59 Sujet du message: Re: Regulator |
danjamds a écrit : | A very interesting discussion.
It should be remembered that most ammeters are in fact voltmeters which measure the voltage across a fixed resistor - the meter just happens to be calibrated in amps. |
Not exactly.
All ammeters and voltmeters are really "galvanomètre", i.e. very sensitive ammeter.
To make a voltmeter, you include a (very) high serial resistor.
To make an ammeter, you include a (very) low parallel resistor (called "shunt" in french...).
In all cases, if you uses the 'meter above it's capacity, you can destroy it. _________________ Si on bricolait plus souvent, on aurait moins la tête aux bêtises. |
