24ct Ducellier Regulator
Poster un nouveau sujet   Répondre au sujet    Forum Panhard - Page d accueil -> English spoken !
MessagePosté le: Dim Mai 10, 2020 18:59    Sujet du message: Re: Regulator Répondre en citant
danjamds a écrit :
A very interesting discussion.
It should be remembered that most ammeters are in fact voltmeters which measure the voltage across a fixed resistor - the meter just happens to be calibrated in amps.
Not exactly.
All ammeters and voltmeters are really "galvanomètre", i.e. very sensitive ammeter.
To make a voltmeter, you include a (very) high serial resistor.
To make an ammeter, you include a (very) low parallel resistor (called "shunt" in french...).
In all cases, if you uses the 'meter above it's capacity, you can destroy it.
Poster un nouveau sujet   Répondre au sujet    Forum Panhard - Page d accueil -> English spoken ! Toutes les heures sont au format GMT + 1 Heure
Page 2 sur 2
